Hello everyone, brainstorming ideas as we will probably enclose our indoor pool. I had an idea to place a pool table in the pool that can be raised from the floor with the push of a button. Does anyone have a good idea for an electric lift that could lift the table 80-90cm straight up? A pool table weighs about 450kg so it needs to be something strong and preferably quiet. If you have other fun ideas of what to do, feel free to drop them here. The pool is a classic 70s concrete pool, 8x3.5m and between 1.80x1.20cm deep.
You only need a 450 kg counterweight.
Please! Just make sure it's easy to restore the pool. It hurts my heart when people ruin something as wonderful as an indoor pool in a '70s house.
  • Like
Freja Te and 3 others
P
A very large number of houses with indoor pools have significant problems with moisture and mold, and sufficient ventilation costs both in purchase and operating expenses. The amount of work and energy consumption makes it so that very few indoor pools are used in the long run.
So for many, it's not worth it, and the house that was bought because it would be nice, cool, etc., with a private pool often ends up with an empty pool that is never used.
Of course, there are people who use them, but I would say they are the minority.
Hydraulics is indeed efficient and can lift most things, and with rupture valves, you can also have safety so it doesn't collapse like a big mousetrap if something breaks.
MrJay
Here are some ideas:
1. Gym or workout room: Since pool areas often have an open space, it can be perfect for a home gym.
2. Home theater: The former pool's acoustics might make it an interesting place for a home theater.
3. Greenhouse or garden room: With the right lighting, you can grow plants or flowers year-round.
If you decide to fill in your indoor pool, make sure to properly seal and insulate the bottom so there are no moisture issues in the future.
There are lift tables for industrial use that can handle more than 450 kg. The problem is rather getting the table to fit under the floor, creating a solution that provides a good floor in the raised position, and getting the table level each time. There are tables that have an extra tabletop which both protects the cloth and functions as a dining table if you want to make it a bit simpler.
A AG A said:
Please! Just make sure it's easy to restore the pool. It breaks my heart when people destroy something as wonderful as an indoor pool in a 70s house.
No, the thought of renovating it is not completely dismissed. But it's fun with new ideas too. Somehow I can probably make use of it, even if it becomes a basement with a TV corner. It's still 28 sqm, so it's like a living room with a poor ceiling height 😅
Unikt namn
Make a ball pit!
Just look how happy one becomes, and 0% risk of moisture problems. 🙃
Young child laughing while playing in a colorful ball pit on a grass surface.
  • Love
AG A
E el_ias said:
Hello everyone, brainstorming ideas as we are probably going to build over our indoor pool.
I had an idea to place a pool table in the pool that can be raised up from the floor with the push of a button. Does anyone have a good idea for an electric lift that could lift the table 80-90cm vertically? A pool table weighs about 450kg so it needs to be something strong and preferably quiet.
If you have other fun ideas on what to do, feel free to drop them here.
The pool is a classic 70s concrete pool measuring 8x3.5m and between 1.80x1.20cm deep.
We converted the pool into a living room 20 years ago, when we bought the house the pool was leaking and a pool liner was installed.
We had a corner sofa and table, wall-mounted TV and new flooring and white-painted horizontal wood paneling on the pool walls.
On the old tiles at ground level, a new floor was laid and a wood stove was installed; behind the stove, a feature brick wall was built for fire protection.
We also had a music system at ground level. And a seating area.
Double openable glass sections and windows. The ceiling height from the pool bottom was 380 cm, so it was airy.
We were very satisfied with the result.
  • Like
el_ias
Z z_bumbi said:
There are lift tables for industrial use that can handle more than 450 kg. The problem is rather getting the table to fit under the floor, making a solution that provides a good floor in the raised position, and getting the table perfectly level each time..
There are tables with an extra tabletop that both protect the cloth and function as a dining table if you want to make it a bit simpler.
I also immediately thought of lift tables or car lifts. If it only needs to be lifted 80-90 cm, a so-called low lift might be interesting. They usually lift about 100 cm. TS, google "low lift" and "lift table." If it becomes "skottrakt" I actually don't know. They are not super quiet either, but it doesn't take long to lift/lower, so I don't know if it is that problematic...
Otherwise, it's probably both quieter and cheaper with a counterweight as someone mentioned and a rope that you use to hoist the table up/down.
I imagine that you plan to have flooring throughout the room flush with the pool's edge, and it's only the sunken billiard table that utilizes the pool space, correct? If it's an issue to get it level, perhaps you could hoist the table above floor level, then extend some sturdy beams attached to the surrounding floor frame, and then lower the table back down onto these.
  • Like
Nyfniken
Now if I remember correctly, the counterweight is not as much as the maximum load. But I don't remember exactly. It was a few years ago I studied...
Some form of lift table is probably the best solution. Quiet? Well, not so much worth it. A hydraulic elevator can have the machine room placed where it doesn't disturb. The downside is that you can't avoid the guides. A cable elevator becomes even more cumbersome... And even more visible. Because the cables have to be above the elevator. The counterweight is the least of the problems. The motor must be directly connected to the elevator. A scissor lift is probably the best option. The weight is actually not a huge problem.
C Ca5M5G said:
We converted the pool into a living room 20 years ago; when we bought the house, the pool was leaky and a pool liner was installed.
We had a corner sofa and table, wall-mounted TV, new flooring, and horizontally painted wood panels on the pool walls.
A new floor was laid on the old tiles at ground level, and a wood-burning stove was installed, with a backing brick wall built as fire protection.
We also had a sound system on the ground level and a seating area.
Double opening glass panels and windows. The ceiling height from the pool bottom was 380 cm, so it was airy.
We were very pleased with the result.
Hi, this sounds very interesting. We have recently bought a house where there has been an indoor pool. The water has been drained. A floor has been built over it. In the cavity under the floor, dehumidifiers run around the clock, in addition to an EPS system being installed to keep moisture out. We will never use this as a pool and are therefore considering possible alternatives. Is it possible to hear what you filled the pool with and how you then established the floor above :-) ?
Click here to reply
