M
Hello, My first thread here : )
Starting a small renovation, New kitchen, ventilated floor, and underfloor heating :)
But I need to start by modifying a couple of rafters for the new kitchen.
Maybe someone here has similar conditions, or knows how to calculate roughly. I want to order the beam as soon as possible! :)
The opening will be 3.6m on a load-bearing wall.
The house was built around 1970, 1.5-story Skidstahus. Snow load 3.5 kN/m2
38-degree roof pitch.
Steel beam is a requirement due to construction height.
LxW: 13x8.2 exterior dimensions
Thanks in advance :)
  • Blueprint of a one and a half-story house from 1970, showing south, north, east, and west facades, with section A-A detailing the roof slope.
  • Blueprint showing three elevation views of a house with a sloped roof, labeled "Saltvik 2:13," scale 1:100, used for renovation planning.
  • Floor plan showing dimensions for a renovation project with labeled kitchen and beam area, including room measurements and layout details.
Hi,
Quick guess IPE180, maybe one size larger. How do I know that? Partly because I calculated it for our 3.6m large offset, and also because the house designer chose the same one for our bay window. However, it's just a single-story, so maybe slightly larger.
Best regards, Andreas
Onsalakorven Onsalakorven said:
Hello,
Quick guess IPE180, maybe one size larger. How do I know this? Partly I calculated it for our 3.6m large deflection, and the house designer chose a similar one for our bay window. However, it's only one floor, hence maybe slightly larger.
I see I've read the drawing incorrectly (or not at all). There's a support in the middle of the house, not along the wall. Then IPE180 should be sufficient, and it takes up little space. Otherwise, some glulam beam might also work well.
Click here to reply
