LillfinneN85
Currently renovating the laundry room in the basement.
We have really revamped a lot, drained the outside with isodrän, replaced sewer pipes, laid tiles on the floors, torn off plaster and replastered the walls.
Now it's time for the ceiling.
The previous ceiling was the original plaster on straw, we've torn that down and now there's only a plank ceiling.
My idea is to space it up horizontally and install Huntonit ceiling and wall panels 600x1200mm.
Partly to avoid spackling and painting, but also because it is designed for spaced c/c 600 mm.
We also want to create space for spotlights and cable routing.
My question is whether Huntonit would work in a basement?
It says it works in bathrooms, so I think potential moisture shouldn't be a problem.
Moreover, the existing planks are made of wood and they've been there since 1943 and are fresh.
Planning to keep it somewhat cooler in the basement, maybe around 17-19 degrees, could that be a problem?
  • Ceiling with exposed wood and straw after plaster removal in a basement laundry room renovation. Walls appear to be made of cinder block.
  • Basement laundry room renovation with debris on the floor, exposed ceiling beams, and remnants of straw and plaster from the old ceiling being removed.
  • Basement laundry room renovation with exposed wooden plank ceiling and new metal studs for wall framing. Concrete floor and pipes visible.
LillfinneN85 LillfinneN85 said:
I'm in the process of renovating the laundry room in the basement.
We've really done a lot, drained externally with isodrän, replaced drainage pipes, laid tile on the floors, ripped off plaster, and re-plastered the walls.
The previous ceiling was original plaster on straw, we have torn it down and there is now only a plank ceiling.
My thought is to space it out in waves and lay Huntonit ceiling and wall panels 600x1200mm.
Partly to avoid filling and painting, but also because it is adapted for spacing c/c 600 mm.
We also want to create space for spotlights and wiring.
My question is really whether Huntonit would work in a basement?
It says that it works in bathrooms, so I think any moisture shouldn't be a problem.
Additionally, the existing planks are wood and they have been there since 1943 and are fresh.
I plan to keep it a bit cooler in the basement, maybe around 17-19 degrees, could that be an issue?
Don't see why it wouldn't work due to possibly slightly elevated humidity, especially if it also works in bathrooms.
However, you might want to check how flat/straight your ceiling is.
For some ceiling panels, it can be very noticeable if it's not flat, others are more forgiving...
  • Like
LillfinneN85
Z
I have huntonit on the entire basement ceiling, extremely convenient. I've even taken down certain parts of the ceiling to add plumbing and electrical installations. Can highly recommend!
  • Like
LillfinneN85
Have also installed Huntonit in the basement. It has been there for 12 years now without problems 👍
  • Like
LillfinneN85
LillfinneN85
klaskarlsson klaskarlsson said:
Don't see why it wouldn't work due to potentially slightly elevated humidity, especially if it works in bathrooms.
However, you should perhaps check how flat/straight your ceiling is.
For certain ceiling panels, it can be very noticeable if it's not flat, while others are more forgiving...
Yes, exactly, I will align the battens with a laser to get it straight 🙂
  • Like
klaskarlsson
Click here to reply
