1,145 views ·
1k views
Are there studs / floorboards 34x160 mm or similar?
Need to replace the floorboards in an older barn built in 1948.
Most of it is concrete floor, but then there's a small part that is a wood shed with a wooden floor.
There are 34mm thick floorboards in varying widths, 150-180 mm.
Now I need to replace some, as it seems wet wood was on the floor and some boards have broken.
But I can't find any studs/boards that are 34 mm thick, except for pressure-treated decking.
Since it's indoors, pressure-treated isn't needed, and 45 mm thick would create unnecessary level differences, I think.
The beams underneath are spaced at c/c 800 mm.
Member
· Västernorrland
· 12 077 posts
It's probably easier to talk to a smaller sawmill. What you need is logs/lumber that are just split to the appropriate thickness. Then you can trim as desired for width.
I checked with the hardware stores in Åkersberga, and they couldn't get this dimension.
I'd gladly accept a few more tips on where it can be found in Northern Stockholm?
Since it concerns a barn, I would buy pressure-treated decking with a thickness of 34 mm. You can easily cut this yourself with a table saw or circular saw so that it fits.
Beijer also has 34 mm construction battens up to 145 mm in width.
https://www.beijerbygg.se/privat/sv...ank-reglar/byggreglar/byggregel-34x145mm-g4-2
Looking at the prices, it seems that decking wood is the most cost-effective option.Pjosk75 said:
And it should work well as a floor in a wood shed; the question is how long I should let them dry before screwing them down?
I plan to lay them edge to edge so it matches the rest of the floor; it's only 1/3 of the floor area that is bad.
The length needs to be 2.93 m on each plank, so I guess I should buy 3.20 m lengths and cut them down.
You can buy them now and screw the floor in tonight if you want and have the energyS Superrobban said:Looking at the prices, it seems decking timber is the most cost-effective.
And it should work well as flooring in a wood shed; the question is how long I should let them dry before screwing them in place?
I was thinking of laying them edge to edge so it matches the rest of the floor; it's just 1/3 of the floor area that's bad.
The length needs to be 2.93 cm for each plank, so I guess I should buy 3.20 cm lengths and cut them down.
Click here to reply
Similar threads
Tåligare reglar till trädäck, finns det?
Altan & Uteplats -
How do I best frame a ball wall where there is no ceiling to attach to either?
Building Materials and Construction Technology -
Can't find studs in the walls, tried stud finder and magnet. Is there a solution?
