Hello,
I'm planning to build a double garage with leca. There will also be a fairly large workshop (lathe, grinder, lathe, car lift, eccentric press, etc.).
So I wonder if a slanted roof 4.5 meters wide is possible. Is it possible to splice the boards with iron as it seems very difficult to find the right length? In short, is this possible? I would prefer to avoid a gabled roof.
Best regards,
Oscar
Best regards,
Oscar
Best answer
Glulam beams are available in optional lengths if you order, but for example, 5 m can be in stock.
It is also perfectly fine to splice ordinary studs, but with a long span, it can result in very high studs and/or a tight spacing between them.
Swedish Wood has calculation programs on its website where you can find suitable dimensions.
Thank you for your response. Now I have options at least.
Kind regards,
Oscar
Kind regards,
Oscar
I don't quite understand how the building is supposed to look.
Double garage and large workshop, 4.5m wide. These two things don't go together.
Building a monopitch roof with a 4.5m width is no problem, if that is your question?
richardtenggren said:
G Gabbe1 said:
I honestly thought that studs didn't exist in that size. Good to hear that they do.G Gabbe1 said:
Self-builder
· 8 623 posts
Generally, you cannot splice a roof truss (which this would become) with iron, you will get a deflection and over time the roof could even collapse. Instead, you should look at a glulam beam, or you need to have a support in the middle (and then you can splice, but usually, a smaller dimension will also suffice).OggeSttrid said:
Hello,
I am thinking about building a double garage with leca. There will also be a fairly large workshop (lathe, grinder, lathe, car lift, eccentric press, etc.)
So I wonder if a sloped roof 4.5 meters wide is possible. Is it possible to splice the boards with iron since it seems to be very difficult to find the right length? In short, is it possible? I would prefer to avoid a pitched roof.
With kind regards,
Oscar
For glulam, 4.5m does not seem to be a major problem even in higher snow zones...
https://www.traguiden.se/konstrukti...uktionsvirke-i-ett-fack/?previousState=000100
https://www.traguiden.se/konstrukti...ar-av-limtra-i-ett-fack/?previousState=000100
Ok, I didn't know this. It was a carpenter friend who thought it didn't exist (he probably never worked with that size)klaskarlsson said:
Generally, you can't splice a truss (as this would then become) with iron, you will get a deflection and over time the roof may even collapse.
Instead, you should look at glulam beams, or you need to have a support in the middle (and then you can splice, but usually thinner dimensions are sufficient as well).
[link]
[link]
Now I think you/we are talking about different things.
If you want an 8m width with a pent roof (what TS calls a pitched roof), you will need trusses or heavy beams; regular studs will not work.
However, a 4.5m width might work with lumber, depending on the roof's own weight, snow load, and how densely the rafters/studs are placed. "Regular" studs are available up to 5.4m at regular hardware stores.
Then it means that you don't need a glulam beam (unfamiliar with the terminology)G Gabbe1 said:Now I think you/we are talking about different things.
If you want an 8m width with a shed roof (what TS calls a sloped roof), then you'll need roof trusses or strong beams, regular studs won't work.
4.5m width, on the other hand, might perhaps work with stud framing, it depends on the roof's own weight, snow load, and how closely the rafters/studs are placed.
Did you misunderstand my answer, or are you intentionally interpreting it like the devil reads the bible?OggeSttrid said:
"It might possibly work with regular timber, it depends on the roof's own weight, snow load, and how closely the rafters are spaced."
Before these things are investigated, I wouldn't dare assume that "ordinary" rafters would suffice.
I misunderstood it. I meant absolutely no harm by it.
Click here to reply
