Quick question - I'm attaching gypsum boards in the garage and I'm wondering if the 25mm screws I bought are the right length or if I should have chosen 30mm.
On the studs/insulation there's plastic foil, then 12mm plywood and 12.5mm single gypsum board. I chose 25mm to avoid puncturing the foil since there's no installation layer.
Will the 25mm gypsum screws work or should I buy new 30mm ones?
