3,189 views ·
3k views
Window frame directly against concrete slab
Hello
I am wondering if one can or should place a window directly on a concrete slab, i.e., without a sill. The window is to be installed in an Attefall house for year-round living. Grateful for quick answers.
Best answer
Thank you for the quick responses. Yes, if that's the case, I was thinking of possibly doubling it. I have used T-syll 7mm for the beams. Thank you so much for the answers. This was my first question here. Should one close the thread after a while when you're satisfied?
T-cell is surely a good product; I’ll let the experts decide which is best.H Helge007 said:
I have placed https://www.isover.se/products/isover-varior-syllisolering under my walls.
The two rolls on it create a higher pressure on a smaller area, which theoretically makes it seal better against irregularities than T-cell where the load is distributed over the entire surface.
Click here to reply
