11,601 views ·
12k views
Would need spacers of 1 mm - 2 mm.
I would need spacers of 1 mm - 2 mm that I can place under another piece so it reaches the right height.
Any suggestions on what I can find at the hardware store (Beijer, K-Rauta, Byggmax, Bauhaus)?
Otherwise, maybe I can just buy something else and cut it apart to use. For example, some cheap plastic placemat from Jysk. They should maybe be 1mm thick or so.
Now I don't know what you plan to use it for. But nail band? Window spacer blocks? Sheet metal, available at Biltema http://www.biltema.se/sv/Bil---MC/Bilreservdelar/Karosseri/Platark/Platark-2000020612/
H
Hallerudsbo
Tool enthusiast
· Värmland
· 3 672 posts
Hallerudsbo
Tool enthusiast
- Värmland
- 3,672 posts
Ikea has 2 mm if you want to cut yourself,http://www.ikea.com/se/sv/catalog/products/50153123/
Click here to reply
Similar threads
Rabatt skulle behöva råd.
Trädgård allmänt -
Hjälp! Skulle behova råd om hur kan jag sänka temperaturen i huset?
Värmepumpar -
Skall bygga en tillfällig bro, skulle behöva input
Metall - stålkonstruktioner, svets och smide -
Hej! Skulle behöva ta bort skjutdörr i vitrinskåp
Fönster & Dörrar -
Skulle behöva hjälp med installation av frånluftsventil
Ventilation
