Hobby carpenter
· Västra Götaland
· 1 474 posts
It looks like they've used screws that are too long.
Hi Anna and welcome to the forum!
Was the big stripe there before? Probably, the screws are too long and have also pushed out the plasterboard.
Sigh... this is why I never hire "professionals" again...
Hello and thank you! No, it wasn't there before, they have botched several things and I'm so tired of continuing to complain. But this is my condominium and it doesn't feel good to sell it like this when it's time.
It is therefore a condominium where the association has hired a company to carry out the plumbing replacement.
I agree with previous speakers. Unfortunately.
Too long screws. Bulges at screws, and the edge is the joint between 2 drywall sheets. One sheet has been pushed out. The latter may also have another explanation than the long screws.
Had it happened to me (completely hypothetically as I will not hire craftsmen anymore), I would have unscrewed the screws and shortened them by a centimeter with a hacksaw ("steel saw") or angle grinder and screwed them back in to see if the damage reverses. If it is a wet room, there should be wet room silicone in the screw holes when screwing them back, so it's a good time to check if they have been careless with this as well.
I understand you, but of course you should complain!A Anna Olsson9713 said:
That needs to be fixed.
But isn't it the housing association you should turn to?
Okay, thank you for your inputs! Is there anything that is difficult to address?
So far, we are still in dialogue with the company that did the plumbing replacement. They are not finished yet and had an inspection 2 weeks ago, but this wasn't visible thenK Kardan79 said:
But then they must tear down the tiles to fix it? On that wall in the bathroom, there is a towel warmer.Cruzze said:
Had it happened to me (completely hypothetically as I will not be hiring craftsmen anymore) I would have unscrewed the screws and shortened them by a centimeter with a hacksaw ("steel saw") or angle grinder and screwed them back to see if the damage reverses. If it's a wet room there should be wet room silicone in the screw holes when screwing them back, so it's a good opportunity to check if they were careless with this as well.
I thought that it's the association, not you or any other cooperative housing owners, that has entered into an agreement with the contractor. Therefore, it should be the association you should complain to, who can then go after the contractor. But maybe it doesn't work like that in practice.A Anna Olsson9713 said:
Yes, maybe it should be like that, but we have a page where we have direct contact with the company.
They finished the bathroom on December 20th. They repainted my hall about 1 1/2 weeks ago and after that, they started to show even more.K Kardan79 said:
