I have noted that my miter saw (Bosch GCM 8, a few years old) doesn't cut perfectly. The result is accordingly... See image.
Now that the damage is done, how do you repair this in the nicest and best way?
I don't want to paint over the moldings, only fill in the actual crack. Wood filler or caulk? What does the general consensus recommend?
…or maybe it doesn't really matter? No result is perfect anyway.
When did you put up the fodren? It might be good to let it sit for a season due to the walls' movements, as new ones are likely to crack quite immediately otherwise.
When did you put up the fodren? It might be good to let it sit for a season to allow for the walls' movements, it's easy for new work to crack pretty quickly otherwise
It's been up since the summer and has looked pretty much the same the whole time. Maybe *slightly* wider gap now than when I put it up.
