Member
· Blekinge
· 10 117 posts
A 45x220 mm C 24 joist with a 4-meter span that is loaded with a point load of 450 kg in the middle will deflect approximately 13 mm, which is 1/300 of the span, commonly used as a limit in many contexts. This applies under the condition that it is a temporary load. For long-term loads, other conditions apply. Three joists give the same result for a load three times as large if it is evenly distributed.
Click here to reply
