1,433 views ·
1k views
Square tube load 100x50x5mm and 3.6m opening? Can it handle 750kg?
But here is how you can calculate:T Tasur said:
https://abrahamssonsjarn.se/app/uploads/2019/09/Tibnor_Konstruktionstabeller-2018.pdf
Member
· Blekinge
· 10 117 posts
If you mean a point load of 750 kg in the middle, it doesn't go so well. The deflection will be 20 mm, which corresponds to 1/180 of the span. If you increase the dimension to 120x80x4, it works.
Click here to reply
