Member
· Blekinge
· 10 117 posts
2 screw-glued 45x70 C 24 can handle a 160 cm span with OK results if you place them at c/c 600 mm and screw-glue a chipboard or similar on the top.
Member
· Blekinge
· 10 117 posts
c/c 300 increases the load-bearing capacity but has only a marginal effect on the deflection. However, it certainly becomes more stable.
Grundstött
· Halland
· 28 345 posts
Member
· Blekinge
· 10 117 posts
According to A, that was how I measured, in order to keep the floor height down. B is much more efficient, however.
Click here to reply
