7,364 views ·
7k views
Spackle cut drywall?
Page 1 of 2
Member
· stockholms län
· 5 posts
I cut the renovation drywall boards lengthwise to make it easier to get them home in the car.
Now the help I hired to put up the boards has placed them side by side without any gap in the joint and without planing a beveled edge on them.
How should I now plaster this in a neat way?
Member
· stockholms län
· 5 posts
It was a good suggestion, thank you. I'll try it.
Member
· stockholms län
· 5 posts
understood, thanks for the thoughtfulness.
Not everyone has a tow bar on their car though...AndyF1 said:
Not sure if you really need to bevel the edges actually.
Put fiberglass or paper tape and spread the plaster 15-20 cm on each side, so you don't see it when wallpapering anyway.
Member
· stockholms län
· 5 posts
Thanks, I know. I didn't have a tow hitch or roof rack and wanted to get the boards home. Now they're on the wall, a bit clumsily mounted, and my question was about making the best of the situation. SBH gave a decent answer that I intend to try to follow. The walls the boards cover are in a summer house, where it doesn't matter so much if a seam is visible here and there.AndyF1 said:
