Hello. I currently have an existing balcony measuring 6000x2200mm. I'm thinking of tearing it down and rebuilding a similar one. The balcony today stands on 8 plinths with 90x90 posts. There are also bolted beams in hangers on the facade. However, I'm hoping to build the balcony on the 4 outer posts and only one bolted bearing beam on the facade. The question is whether this will hold. I have the usual 0.3kn/m² + self-weight.
Attaching pictures of the existing balcony. I hope someone can help me. I've looked at the wood guide and some other resources but haven’t received any clear answers to my questions through them.
I think you have more load than 0.3 kN/m2 = 30kg/m2.
The remaining columns, beams, and plinths should hold, as they do not receive any significant load addition. The tricky question is rather how you should attach the ledger board to the wall, both in terms of handling the loads and in terms of moisture.
Remaining columns, beams, and footings should hold, as they don't get any significant increase in load. The tricky question will rather be how to fasten the bearing beam to the wall, both in terms of handling the loads and moisture.
You could use threaded rod, with or without a threaded sleeve. Tec7 or pl400 or another compound to seal. Loctite in the sleeve if using it. It should be added that there are already bolted joist hangers on the facade at c/c 600. Will be able to use those holes.
