A Anemon86 #1 Member · 265 posts 13 Sep at 5:25 PM Anemon86 Member 265 posts 13 Sep at 5:25 PM #1 I have made a hole in a wall to pass through pipes and cables. Now I need to close this hole to prevent cold air from coming in. Which junction box cover/cover cap should I use, or are there other alternatives? I got the diameter to 80mm. #hole #clog
Claes Sörmland #2 Member · 34 896 posts 13 Sep at 5:55 PM Claes Sörmland Member 34,896 posts 13 Sep at 5:55 PM #2 Maybe: https://www.clasohlson.com/se/p/32-2177
A Anemon86 #3 Member · 265 posts 13 Sep at 7:09 PM Anemon86 Member 265 posts 13 Sep at 7:09 PM #3 Claes Sörmland said: Maybe: [link] That was a good idea. But it keeps falling off all the time. The clamps don't reach the wall's sides. Could one use fogskun and then press the socket cover into place?
H HSP #4 Member · Dalarna · 2 840 posts 13 Sep at 7:11 PM HSP Member Dalarna 2,840 posts 13 Sep at 7:11 PM #4 Cut a round piece of styrofoam or ground insulation and put it in the hole, seal with a little soft sealant, so it can be easily opened if needed.
A Anemon86 #5 Member · 265 posts 13 Sep at 7:14 PM Anemon86 Member 265 posts 13 Sep at 7:14 PM #5 H HSP said: Cut a round piece of styrofoam or ground insulation and put it in the hole, seal with some soft sealant so it can be easily opened if needed. Would foam plastic work?
H HSP #6 Member · Dalarna · 2 840 posts 13 Sep at 7:15 PM HSP Member Dalarna 2,840 posts 13 Sep at 7:15 PM #6 Yes, it works.
K Kasken #7 Member · Östergötland · 1 204 posts 13 Sep at 7:25 PM Kasken Member Östergötland 1,204 posts 13 Sep at 7:25 PM #7 Will there eventually be a need to change anything in the hole? If not, then it's just a matter of filling the hole with foam sealant?
