I am planning a small shed and am currently wondering how to handle the load-bearing above doors and possibly windows. There's a roof truss directly above the door opening, and somehow the force must be directed downwards.
Here's what my current proposal looks like. These are the trusses visible above.
So I place a beam above the door opening, oriented on edge. Then that beam is also supported underneath by two metal brackets (red color).
Notch or cut out a section of the vertical studs and place a strong lintel directly under the top plate on which the roof truss rests. This lintel (e.g., 95 x 145 on edge) should rest on the vertical studs.
Click here to reply
