12,327 views ·
12k views
Recipe for "sluring" for casting
I'm planning to cast 22mm post shoes into 23-24mm holes I've drilled in the rock.
I remember there's something called "sluring." A mixture of water and cement that can be used?
Does anyone have a good recipe and know how to do it?
I don't have pure cement at home... is it okay to use mortar mix B and water?
You're supposed to use expanderbetong if I'm not completely mistaken.
Edit: Just saw that there was very little space...
Exactly... I thought that anchor adhesive was a bit expensive and overkill... Also, there's not much extra space in the hole between the iron/rock.
Can I just pour a very loose mixture of mortar & water into the hole and then press down the rebar?
You dose the anchoring compound before inserting the iron, and a given amount depending on the hole dimension/iron dimension is usually the measurement scale on the tube.
I hope you get an answer from someone else regarding the cement, because I don't know much about that...
I sometimes use a cheap two-component filler. Usually polyester-based, sometimes with short glass fibers in the mixture. Has worked well so far.
Click here to reply
