I have built a garden bench and a table from pressure-treated wood. It will be outside all year round. It would be nice to fill in all the screw holes and such, but I don't know which filler I can use. It seems that wood filler is only for indoor use. Can it still be used? I have also discovered some cracks in the wooden house facade, can I use regular wood filler for that as well?
The attempts I've seen have not held up well. Outdoor wood varies with how wet it is, and putty does not and comes loose.
Outdoor glue and sawdust?
Personally, I've unscrewed one screw at a time and replaced it with glued wooden plugs. Not invisible, of course.
/ATW
/ATW
Try using window putty?
Oh, so advanced, but probably looks nice! Thanks, now I know not to use regular filler. Interesting with glue and sawdust, but I think it'll be fine anyway.A ArneTW said:
Our previous house we built new.. the horizontal paneling cracked in places as it gradually dried, we used Nordsjö paint sealant in the cracks and then painted over it worked excellently!
The tube states that it can be used outdoors but should be painted over immediately.
Best regards, Patrik
Thanks for the tipP Patrik.L said:
Click here to reply
