Going to stretch ceiling panels between my rafters at 1.2m centers. Since I want the smallest possible construction height (every cm is important), I was planning to put an OSB on each rafter and a 13mm gypsum board on top of this. I'm a bit unsure about OSB, can this span be okay? A plywood board would probably work fine, but hardly a chipboard - OSB is somewhere in between in strength, right?
There is strength and strength... screws hold well in OSB but in terms of bending stiffness, I experience, from my own experience and without having seen any figures on it, that OSB is rather more flexible than chipboard of equivalent thickness. By the way, I probably wouldn't even use plywood in this way. So I agree with the previous - slatted.kalubah said:
Moderator
· 57 882 posts
A variant I know some people use is to install false trusses, i.e., trusses of smaller dimensions between the real ones.
Click here to reply
