24,295 views ·
24k views
My tenant has glued carpets to the walls. Help!
Know-It-All
· Västra götaland
· 11 022 posts
Signposted fire extinguisher outside the door and bars on the window suggest that it is not an ordinary private individual who rented it.
Assume you should look at the contract if you want to cast a shadow on someone...
As for the glue, it's probably easiest to glue on renovation wallpaper and paint...
Renovation wallpaper! Thanks for the tip.
Smart alek
· östergötland
· 2 818 posts
I had started by sanding with the giraffe and 40 grit paper
Self-builder
· 8 650 posts
Or you rent it out again to someone else with the same business and keep the deposit. Then you can increase the rent because it is adapted for a studio or whatever it may be.klaskarlsson said:
