Does anyone have experience working with Lux-elements boards? I am going to build a round shower and wonder if there is anything special I should consider. Where is the best place to buy these?
Use the circular saw + an old blade you don't mind damaging.
Give a call to the person responsible for these boards at KGC; you can get some good tips there about things like the groove distance to achieve good symmetry with the rounding. I think you also want to figure out how to reinforce the inside (where you've cut grooves) when dealing with such large surfaces.
I haven't found a good place to buy these boards. I have 20% off at Fredells, but it turns out almost as expensive as buying directly from KGC.
There are probably other boards than LUX that are cheaper.
I have received a small brochure from Beijer Bygg where they explain a bit about reinforcement etc.
Are they expensive stories??
Yes, the tiles are expensive. For a whole shower, it's probably around 4000 krona I guess.
Check with your local tile dealer. Found similar panels from another brand for less than half the price. Haven't picked them up yet, so I don't remember the brand, but if I remember, I can get back to you.
Click here to reply
