When I read about truss roof structures, I get the impression that they are meant to be self-supporting. Is this something one can always assume to be true, or are there exceptions? Can I assume that yellow-marked walls are safe to demolish, or do I still need to consult an engineer? I estimate the length between the original outer walls to be about 8m. The house is from the 1960s. An extension has been made to the house where the outer walls have been moved out in two of the rooms and a new beam has been installed instead, so I assume this should not affect the basic construction. Let me know if further information is needed to make a judgment, and I can provide drawings if necessary. Thanks for your help!
  • Blueprint of a house section showing roof trusses, two floors, and wall measurements; related to truss self-supporting query.
  • Floor plan of a 1960s house showing rooms with highlighted walls, indicating walls in question for removal. Includes kitchen, living room, and bathroom.
BirgitS
The highlighted walls are likely not load-bearing, with the exception being if there is a beam in the living room ceiling.
  • Like
fribygg
Click here to reply
