Well, that's how it usually looks. The upper one is actually unusually little rusty.Andreas Lundgren said:
Rust is simply a chemical reaction between iron and oxygen (4Fe + 3O2 → 2Fe2O3, to put it chemically). Since there is quite a lack of oxygen inside the structure in which the reinforcement is embedded, the rusting does not continue—as long as no part of the reinforcement is exposed, of course.
That the entire steel is covered with rust is not unusual. However, there seems to be a bit too much rust on the lower part for me to approve it. Surface rust is okay, but not loosely adhering rust on a larger part of the surface.
I have probably never seen other islands "rusty" rebar items (neither mesh, posts, iron, etc.)
thought they were all like that!
They're always outside (in all weather) so it's not really surprising if they rust...
I'll definitely check if I see something "shiny," on anything, next time I visit the building supplies store (now that I know they exist..)
There is rust and there is rust in this world. Red rust (surface rust) does not affect strength. However, the dark brown pit rust does. In the picture, it doesn't look like there's any pit rust, except perhaps on the left side of the image. However, that could just as well be shadows from the grooves, so it's not possible to say for certain from the picture.useless said:
Surprised a friend when we were going to cast a smaller piece, with completely stainless reinforcement bars bought at Biltema.Snigla said:
I've probably never seen other "rusty" reinforcement stuff (neither nets, posts, iron, etc.)I thought they were all like that!
They're always outside (in wind and weather) so it's not really surprising if they rust...
I'll definitely check if I see something "shiny," on something, next time I visit the hardware store (now that I know they exist..)![]()
Bought them there solely because they are indoors, and I wanted to surprise.
I'm mostly thinking that the concrete should adhere to the reinforcement. Even if it doesn't continue to rust, it should still hold, I think.ricebridge said:
The upper one is one of 8 hand-picked I took at Byggmax. The lower one is a panic buy at PoG and it was the last they had left. Now I've polished it a bit with the angle grinder.Snigla said:
Thanks for all the answers!
I have now polished the lower one (a panic purchase, the last example). I'm casting a frame now, but will soon cast on a whole foundation and order materials for it.
Many designers, as well as inspectors, require the rebar to be rusty for better grip.Andreas Lundgren said:
You can rest easy. (Edit: OK, not many. But it's also not uncommon)
As long as you don't see that the rusty iron is significantly larger than the others, there's no danger.
A little trivia is that some suppliers claim that their products should be stored dry, which is just pure nonsense.
Click here to reply
