6,926 views ·
7k views
How old wood can you expect when buying "new"?
I just bought X number of square meters of 34x145 pressure-treated timber. I find it to be faded, there are "roses" on all the ends, you can see that it has been handled multiple times in a bundle, etc. Otherwise, it is very worn with flaked splinters and handling marks as mentioned. I checked the label from the manufacturer, and it was manufactured/sawn/treated in January 2024, and I bought the timber from the supplier/building merchant in July, so it's half a year old timber.
How new/fresh timber should/can you expect to get when you buy NEW decking?
Without knowing exactly, we usually buy approximately 12 months, however, printed decking should not differ so that you get a bundle of newly printed and one that has been standing for almost a year because then there will be a big appearance difference.
Half a year is no time for treated wood, but rather reasonable. A major advantage is that the wood does not become as heavy to lift since it has had some time to dry.
You need to upload pictures of the handling damages in order for comments to be made.
The appearance difference is gone after a winter and a summer, and all the pressure-treated becomes roughly the same, provided the decking is outdoors.Rejäl said:
Well, that is not our experience; we have had a couple of decks over the years that haven't evened out after a few years..S skogaliten said:
It all depends on how much sun exposure the old bundle had, as well as if the customer treats the decking before the color variations have stabilized..
The age is not unusual, but didn't you have the opportunity to check the condition before?R RallyrompanCB said:I just bought X number of square meters of 34x145 pressure-treated timber. I feel that it is faded, there are "rosor" on all the ends, you can see that it has been handled in bundles multiple times, etc. Additionally, it is very worn with splintered chips and marks from handling as mentioned. I checked the label from the manufacturer and it was manufactured/sawn/treated in January 2024, and I bought the timber from the supplier/building store in July, so timber that is half a year old.
How new/fresh timber should/can one expect to get when buying NEW decking?
I agree with the others here, age practically doesn't matter, and in some respects, slightly more "aged" wood can actually be better than something that's completely fresh.
Bleaching and large color variations can be grounds for complaints, but it very much depends on how forgiving the situation is. If all the wood is approximately equally bleached, I would just go with it.
When it comes to the splintery and marked wood, there are two scenarios: if the majority of the wood is that poor quality, you should just send it back. But if it's "manageable" amounts where you can't turn or flip to make use of them, I would set it aside and file a complaint once you're done.
You decide what you want. Just go to the hardware store and choose exactly which boards/planks you want, and which not. You can also ask them to open another bundle.
If you have ordered home delivery, just go there and exchange them. However, do not expect any compensation for the delivery, just because the timber is six months old. As mentioned, the age is almost irrelevant. It's the condition that is decisive. Six months is considered very fresh timber. Newer pressure-treated wood is not fun, as it is almost damp. Very heavy and will shrink a lot.
Okay, thanks. Yes, it was home delivery and I understand about the age but it just felt like they found this bundle "at the back" after a lot of handling. Just so tired of not having that sense at the lumberyard, to want to send decent material.A AG A said:You decide what you want. Just go to the building supply store and choose exactly which boards/planks you want, and not. You can also ask them to open another bundle.
If you have arranged for home delivery, just go there and exchange it. However, don't expect any compensation for the delivery because the timber is six months old. As mentioned, the age is almost irrelevant. It's the condition that matters. Six months is considered very fresh lumber. Newer treated timber is not fun, as it is almost damp. Very heavy and will shrink a lot.
Okay, well I actually agree, but I was really disappointed that they sent the leftover bundle that they hadn't gotten rid of until now.Dowser4711 said:
I agree with the others here, practically speaking, the age doesn't matter, and in some respects, it's even better to have slightly more "age-worn" timber than something that's completely fresh.
Bleached and with large color variations could be a reason for complaint, but it greatly depends on how long the piece is. If all the timber is equally bleached, I would just proceed with it.
When it comes to splintering and marks, there are two scenarios: if the majority of the timber is that poor, you should just send it back. But if there are "manageable" amounts where you can't twist or turn them to be usable, I would set them aside and file a complaint once you are done.
Yes, I was really mostly disappointed that they send "damaged boring" wood.Rejäl said:
Paul-Staffanstorp
Renovator
· Skåne
· 8 989 posts
Paul-Staffanstorp
Renovator
- Skåne
- 8,989 posts
Where did you order it from?
6 months is quite fresh because it needs time to be harvested and transported, etc. as well.
However, most places you order from typically have no problem replacing items if they are in very poor condition.
It could have been inside a hiv, for example, and would be impossible to see before delivery.
If it is that damaged, you should file a claim for the bundle; if it is individual boards, document before breaking the bundle and check what the lumber yard says about it.
You are aware that timber is delivered by truck, often a truck with a trailer at a time, so lumber yards usually have a stock they pick from?
