4,869 views ·
5k views
How long staples are needed to fasten wind protection foil?
But the staple is equally exposed to moisture, right?A Almost0.5acres said:
I think it's good to have stainless staples where they are exposed to moisture.
However, if you mean that the staple doesn't matter after the studs are nailed and thereby hold the wind barrier, there might be something to what you're saying.
We use 8-10 mm even though we use a hammer tacker..Mikael_L said:
But the staple is probably just as exposed to moisture?
I think it's good if there are stainless staples where they are exposed to moisture.
Though, if one means that the staple doesn't matter once the studs are nailed in place and thus hold the wind barrier, then there might be some truth to what you are saying.
Stainless isn't necessary..
4mm is very short; if it's windy the day you install, it'll likely come loose for you…
Click here to reply
