Planning to extend the house with a garage on the basement level, a living room on the entrance level, and a bedroom on the upper floor.
The garage has external dimensions of 7.4m long and 5.5m wide with a ceiling height of 2.1m.
Does anyone know what dimension I need for the floor joists? Since I don't want to lose too much ceiling height, maybe c/c 300 is recommended?
Grateful for responses.
If you use 70x220 (a local sawmill can arrange this, you have end-year problems getting the right length at the builders' merchant) with cc300 and screw-glue the floor chipboard, it MIGHT be enough, but it's on the edge, I would say.
if you have a span of 5.5 m you might need to reconsider.
It won't work with the timber dimensions mentioned.
Either you need support in the middle or significantly stronger beams.
Thank you for the answers!
I would prefer not to have posts in the garage, but I understand the span is quite long.
I saw on moelven.se that according to their calculations, a glulam beam 56x270 cc600 would suffice.
What size might be needed if using a steel beam instead?
Click here to reply
