I don't want to cast a concrete slab for a 15m2 "friggebod" but I want to have tiles in it.
How should I frame the floor joists and which sheet material should I choose to prevent the grout lines from cracking due to flexing in the construction and/or temperature changes?
The "friggebod" will be unheated.
Regla as usual with c/c 600, apply 22 mm floor chipboard and then floor gypsum or fiber-reinforced floor leveling in at least 12 mm. For tips on which dimensions to use for the joists, you can check the Träguiden tables, I have collected the most common ones here.
Click here to reply
