Hello,
I am going to build a lean-to roof of 15 m2 (5 in length and 3 in width) and am deciding between glass and channel plates. Regardless, it will be a cassette system with either 3 or 4 rows and then CC 75 or CC100 between the rafters. In the front, there will be two posts with a 3-meter distance, and at the back, the rafters will rest on a beam. On one long side, there will also be an extra post which allows us to easily build a trellis. What dimension is reasonable for the beam, posts, and rafters in the different cases? At the building supply store, they couldn't calculate it and then suggested going bigger with glue-laminated posts 115mm*115mm and rafters as laminated beams 66mm*315mm.
I live in snow zone 2.
Grateful for all the help I can get.
Fredrik
