Which table are you looking at? Sounds more like you're looking at a wall stud. Since Robban doesn't specify the height of the column, it's quite bold to claim that it will hold...Gabbe1 said:
As I wrote, this applies under the condition that the column is braced against buckling, and then it holds.Krawk said:
If it is to stand completely standalone, there is a risk that it may buckle.
In that case, you should screw/glue/nail 2 pieces together to be on the safe side.
Click here to reply
