10,705 views ·
11k views
Calculate angle easily? For wardrobe to fit in slanted ceiling.
But how do I know how far up to measure from the back of the framework to the wall?13th Marine said:
you should measure from the floor to the ceiling where you want the back to be. If it should stand against the wall, measure at the wall.
Kan själv!
· Trelleborg
· 19 990 posts
You can measure A just as I showed in the picture, from where the sloped ceiling meets the wall to the edge of the board.M Förstagångsköparen said:
It can also be measured at the floor.
Instead of B, you can use the height from the floor to where the sloped ceiling starts.
Make sure the disc is level before measuring.
There are 32 cm left to the wall. It's not visible in the picture, but the sloping roof itself is 90 cm sloping roof. The wardrobe is 58 deep and will stand at the outermost point (where the roof begins to slope).13th Marine said:
Place a laser on the floor 58 cm out (if that's the depth of the closet). When it shines up on the wall, you'll get the line and can measure on the wall towards the sloped ceiling. Then measure the height between the floor/sloped ceiling at the furthest point...
So there will be a gap behind?
Then move line A upwards until it becomes 58 cm.
Upward towards the ceiling. Line A should be horizontal (level, parallel with the floor). When the measurement from the sloped ceiling to your board is 58 cm (A), you have found where the cut C should start.
Click here to reply
