1,530 views ·
2k views
Best way to mill away 5cm ytong from facade?
Hello!
I have about 35 m2 of Ytong that I need to mill down approximately 50mm.
A hell of a job that I don't really know which machine would handle it?
I tried with one like this, but it removes far too little:
https://www.amazon.se/dp/B09S5T7YGF?ref_=pe_109251361_1104560371_fed_asin_title
Is there something good you can recommend here? I want something that removes a lot of material at once, for example, a flex won't work.
Best regards, Erik Wedlund
What about a groove cutter, like https://www.ramirent.se/hyra/byggma...dling/frasar-handhallna/betongsparfras-979568 set at 50mm
Then you get two grooves and break away the middle part.
But if you run grooves across the entire wall with the same spacing, you can break away 50mm pretty quickly.
And finish with the one you have if you are not satisfied with the surface.
Is it an exterior wall with a load-bearing function? If ytong is milled down by as much as 50mm, the load-bearing capacity will be significantly reduced and will tend to crack. You should probably explain why this action is necessary, as well as what might be applied on the outside later.
I'm aware of all that.J jonaserik said:
Barely any load on the walls and 350 thick today
AHA maybe then it has become too large in area and received a setback from the municipality's measurements. It's unfortunate with such things, but if they accept it, you're lucky that you can reduce it a bit. Then the best approach would be to cut grooves with a maximum of about 10 cm apart (best with 50 mm then the piece pops out easily) and start horizontally at the bottom, 50 mm deep with a blade and chisel away the middle part. It's a really crappy job and a lot of dust flying around, but if you have to do it to achieve the results, then what can you do?
Click here to reply
Similar threads
Bästa sättet få slät vägg i kök? Nybörjare
Kök -
Bästa sättet att isolera 260 m² högprofilerad plåt inifrån?
Isolering -
Glasfiberväv på vägg/tak - bästa sättet att ta bort?
Färg, Måla & Tapetsera -
Bästa sättet att täta 1 cm glipa mellan dörrlist och klinkers?
Badrum -
Vad är det bästa sättet att stabilisera och jämna ett befintligt golv
Golv
