2,308 views ·
2k views
Best way to apply Water Glass K12?
Hi!
I am going to apply water glass k12 on my outdoor concrete floor. You should first dilute it 1:5, then 1:4, 1:3, 1:2, and maybe 1:1 if it hasn't already become saturated.
I can imagine that the first coat at 1:5 will absorb a lot, and therefore I'm wondering what method would work best to apply/spread the water glass? Is it to pour it out and then distribute it with a broom, or should you roll it out? Or should you use a pressure sprayer?
Is there anyone with experience with Water glass k12?
Diversearbetare
· Göteborg
· 10 697 posts
Pressure sprayer. Adjust the nozzle for a coarser spray, not mist.
Diversearbetare
· Göteborg
· 10 697 posts
A bit thicker, but it's nothing that affects the application. However, you should probably apply it when it's cool and windless so it doesn't dry out too quickly or blow away. The solution should penetrate into the pores and make the concrete more or less waterproof. If you still get small puddles, a regular broom can be useful to spread out the liquid.T trasan said:
Yes, you might be right, thanks for the tips.Johan Gunverth said:
A bit thicker, but it doesn't affect the application. However, you should probably apply it when it's cool and still, so it doesn't dry too quickly or blow away. The solution should penetrate the pores and make the concrete more or less waterproof. If you still get small puddles, an ordinary broom can be useful to spread the liquid around.
Click here to reply
Similar threads
Hur man på bästa sätt drar och isolera ventrör på vind
Ventilation -
Hur byta rutten råspont på bästa sätt?
Tak & Vind -
Hur lagar jag grundsockeln vid hörnet på källartrappen på bästa sätt?
Grund & Markarbeten -
Hur fyller man på filtermassa på bästa sätt i avsyrningsfilter
Vatten & Avlopp -
Bästa sättet få slät vägg i kök? Nybörjare
