28,337 views ·
28k views
Best tool for cutting nails?
S
SueCia
Electronics enthusiast
· Dalarna
· 5 582 posts
SueCia
- Dalarna
- 5,582 posts
I am renovating my daughter's bedroom, and we've torn down the old masonite boards on 2 interior walls; the other side of the walls are nice and newly wallpapered, so I won't do anything to them. The masonite is nailed with nails that go through the studs and stick out about 1 CM on the other side.
Bending the nails is not an option, as it would make it almost impossible to tear down the other side in the future if needed. So, cutting or maybe trimming? What do the experts say, I would guess there are at least 150 nails.
Member
· Nuevo Estockholmo
· 3 529 posts
Tiger saw with metal blade
http://www.jula.se/catalog/verktyg-.../elektriska-multiverktyg/multiverktyg-010644/
Good for many other things too.
Member
· Norrbotten
· 585 posts
I had a friend who held up a disc as protection and used an angle grinder, I think. Or a tiger saw as above with a more expensive metal blade.
S
SueCia
· Dalarna
· 5 582 posts
SueCia
- Dalarna
- 5,582 posts
It sounds a bit strange with masonite in the bathroom, I agree. But if it's a waterproof floor covering, it stays sealed regardless of what wall it's glued on.SueCia said:
Use a multi-tool to cut the nails if you have to.
(If you put up 12mm gypsum, you might not have to worry about them at all, if you can get the board exactly where it needs to be, just press it with a rubber mallet, assuming the nails stick straight out from the stud).
