Need to repair larger damages in a laundry area with this fiberglass fabric with a diagonal structure. I tore down the damaged pieces completely only to discover that I couldn't find this pattern, herringbone is the closest match. Has anyone seen this for sale anywhere?
It's not an option to replace all the fabric with a new pattern as it is very hard to access.
  • Wall with fibreglass weave in a diagonal herringbone pattern next to a white and blue control box with a dial.
Best answer
P phosun said:
Need to repair larger damages in a laundry room with this fiberglass fabric, with a diagonal structure. I tore down the damaged sections completely only to discover I couldn't find this pattern, herringbone is the closest. Has anyone seen this for sale anywhere?
Replacing all fabric with a new pattern is not an option as it is very hard to access.
Hi.
Take a small piece of fabric with you to your local paint store and they might be able to help you.
Regards, Alexander.
A small update, I followed the advice from Scsi above and turned to a paint store. They had samples from Swedtex, not exactly my pattern but close enough. Fiberglass fabric is obviously not so popular anymore but I was impressed with the pattern selection from Swedtex. It costs significantly more than the bulk products often found in DIY stores; my diagonal pattern cost about 1300 SEK for 30x1 m2. In my case, this was worth it.
  • Like
Scsi
P phosun said:
A small update, I followed the suggestion from Scsi above and turned to a paint store. They had samples from Swedtex, not exactly my pattern but close enough. Fiberglass fabric is apparently not so popular anymore, but I was impressed by the range of patterns from Swedtex. It costs significantly more than the bulk product you often find in building stores, my diagonal pattern cost about 1300kr for 30x1 m2. In my case, it was worth it.
Hi.
Glad it worked out.
Click here to reply
