9,001 views ·
9k views
Filler that doesn't shrink for filling large holes in wooden wall?
I am currently renovating the bathroom and will be chiseling out trenches in the partition wall that is covered with board so that the electrician can lay his conduits recessed. I want to fill in the trenches again before I apply the waterproofing on the board.
I am therefore looking for a filler that has good adhesion to wood and works in layer thicknesses of up to 10 mm at least. The filler doesn't need to be sandable.
Ordinary wood filler would shrink and crack, and I would prefer to avoid having to apply multiple layers of filler to fill the holes.
What filler works well for this?
Looking forward to your opinions!
Grundstött
· Halland
· 28 345 posts
It may sound a bit odd to your ears, but a filler that is easy to work with, cures quickly, is easy to sand, and does not shrink is Plastic Padding Elastic.
However, the volumes that need filling should not be too large, of course.
Grundstött
· Halland
· 28 345 posts
Click here to reply
