10,864 views ·
11k views
How do I calculate which glulam beam is needed?
How's it going Justus? Are you getting anywhere?
Best answer
Member
· Blekinge
· 10 117 posts
If one can assume that the beam does not need to handle any roof loads (which I don't know) but only floor loads from the attic floor and roof loads from the veranda, then a 4 m long glulam beam should have the dimension 90x450. 190x360 has the same capacity. I have calculated with a distributed load of 19.75 kN/m. Personally, I would first conduct a proper measurement.
I don't have the space under the veranda beams, only about 15cm. Or can you bolt the beams on the side of the glulam beam?
Member
· Blekinge
· 10 117 posts
You can use some form of heavy forging fitting, a type of enlarged joist hanger. Go to a blacksmith or a mechanical workshop.
Great! And how much worse is a homemade beam, e.g., 8x45x195?
Member
· Blekinge
· 10 117 posts
What does 8 stand for?
8 pieces to get 195x360
Member
· Blekinge
· 10 117 posts
I am not an expert in manufacturing laminated wood, but if you use C 24 timber and a suitable type of glue and can apply proper pressure, the difference should not be that significant. However, it requires quite a few clamps/glueknektar.
Screw glue? Or will it be worse?
Member
· Blekinge
· 10 117 posts
I don't think screw gluing is an option when you have so many lamellas. If you use dimension planed wood, you should edge saw the boards first so you don't get any round corners in the construction.
Are those too weak? https://www.jula.se/catalog/bygg-och-farg/beslag/byggbeslag/vinkel-skarvjarn/vinkeljarn-340037/J justusandersson said:
Member
· Blekinge
· 10 117 posts
Yes. I don't think the ones you need are available ready-made.
How powerful do I need them to be then?
Member
· Blekinge
· 10 117 posts
Go to a mechanical workshop and present the problem. Show pictures of your porch beams and say that you want enlarged beam shoes that should withstand at least 15 kilonewtons (about 1500 kg).
