3,839 views ·
4k views
Help with sizing roof beams
Page 1 of 2
Hello,
I need help sizing the roof beams (glulam) for an attached garage. Shed roof with a 3-degree roof pitch and with a roof terrace. Snow zone 2.
Grateful for any help.
Try entering your values hereS SSlangen said:
https://www.byggbeskrivningar.se/dimensionering/med-meny/?cid=931
Member
· Blekinge
· 10 117 posts
I don't think construction plans work when you're going to have a rooftop terrace. Laminated wood beams with about a 10 m length at c/c 600 mm need to have substantial dimensions, preferably 140x405. If you splice the beams over the partition wall, you can manage with 140x315 and even smaller over the narrow part.
The idea is to share the beams between the wall, so the beam length will be 6.5-7m.
What loads come from a rooftop terrace?
Can I assume that snow load and "max" load do not occur simultaneously? I mean, no one will be on the terrace when there's a lot of snow...
Member
· Blekinge
· 10 117 posts
The so-called useful load (people and furniture, etc.) for a terrace is 3.5 kN/sqm. Snow does not need to be considered at the same time.
Member
· Blekinge
· 10 117 posts
No. Snow zone 3.5 means that the basic value of snow load on the ground (in a 50-year perspective) is 3.5 kN/sqm. The actual value then depends on form factors such as roof type, roof pitch, risk of snow pockets, and additional conditions. The actual value can be both lower and higher. The maximum deflection for a roof is 1/300 of the span. Additionally, one should check the flex when it is to be used as a terrace.
Member
· Blekinge
· 10 117 posts
Snow zone 2 should be in Norrtälje. If you can insert 3.5 kN/sqm then it must be correct.
Member
· Blekinge
· 10 117 posts
Tell me your conclusion, and I can say if it is correct.
Construction veteran
· 340 posts
Off topic as it may be, it must be said, Justus - goodness, you are so kind and helpful!
Member
· Blekinge
· 10 117 posts
There are surely some who think I'm stealing their jobs... I have very good tools, so it's not a huge effort.
· 340 posts
Member
· Blekinge
· 10 117 posts
No. I cannot deliver any documents.
