3,871 views ·
4k views
Scissor truss will I need glulam beam too?
It will have an asymmetrical gable roof with a span of 8000mm.
Do you think a scissor truss could handle these conditions I've sketched without having to support it with a glulam beam and maybe a support in the middle of the house?
It features tongue and groove boards and concrete tiles.
The house dimensions are 8000mm x 18000mm
I hope so too because I don't draw that wellandersmc said:
But you think it's possible and will be a reasonable solution?
It would be nice to avoid glulam and having to unload onto an internal wall.
8 meters width is not that much.
You can manage 10 with regular W trusses and CC 120 built with regular timber, so it definitely can be done with a scissor truss on 8 meters.
Then maybe it becomes profitable to reduce the CC measurements a bit, but that's something a "proper" designer needs to calculate.
I have free-standing trusses (symmetrical) with an 8m span, 32º exterior and 25º interior, completely open to the ridge inside. If you have the knowledge and tools, it should be possible to make them asymmetrical just as well. Depending on the angles and snow zone, it may require c-c 900 or even c-c 600.
Click here to reply
Similar threads
AI, kommer det här forumet behövas?
Teknik -
Kommer vi behöva kyla?
Värme allmänt -
Nu övergår en gammal dröm till förverkligande men jag kommer behöva hjälp!
Hemma hos -
Finns det nytillverkade kakelugnar/rörspisar som aldrig kommer att behöva renoveras?
Ved, Pellets, Flis -
Kommer behöva höja yttertaket ca 150-200 mm.
Tak & Vind
