Hello! Attic wall removed, now we need to level the plastered brick inside so that it aligns evenly with the white wall on the left in the picture. What type of plaster(?) should I use to make it look nice (and preferably easy to work with)? Preferably something that adheres well to both brick, the plaster above the brick, and the wall on the left (preferably on gypsum as well, of course).
Thanks a lot in advance for the help!
  • Exposed brick and plaster wall beside a white wall and an adjacent drywall in an attic space.
  • Close-up of a rough brick wall with plaster remnants on the surface, adjacent to a smooth white painted wall, showcasing renovation work.
Interesting thread! Waiting eagerly for the first real answer.
A
Gypsum mortar is probably the easiest for you, but I would have plastered with plaster mortar C...
  • Like
Anne G
Rejäl said:
Gipsbruk is probably the easiest for you, but I would have plastered with plaster mix C..
Thanks for the response :)
Ok, do you mean that you used gypsum plaster FIRST and then plaster mix or ONLY plaster mix? And why in that case?
A
J Jörgen Petersson1 said:
Thanks for the answer :)
Ok, do you mean that you used plaster mortar FIRST and then render mortar or ONLY render mortar? And why in that case?
Plaster mortar is easier to work with, adheres more easily but is worse from a moisture and durability perspective..
Render mortar C is more durable but is probably harder for you as a novice to work with..
But both will do in your case..
Rejäl said:
Plaster is easier to work with, adheres more easily but is worse in terms of moisture and durability..
Plaster C withstands more but is probably harder for you as a novice to work with..
Ok, both work on their own then?
What is bad in terms of moisture with the plaster?
And the last question: does the plaster adhere to both the render, the brick, and if needed on the plasterboard?
Big, big thanks for your answers!!! :D
I also wonder about moisture when it comes to gipsbruk?
  • Like
Jörgen Petersson1
A
Ok, both work individually then?
What is bad from a moisture perspective with the gypsum plaster?
And the last question: the gypsum plaster adheres to both the plaster, the brick, and if necessary, to the gypsum boards?
Huge, huge thanks for your answers!!! :D
Here you can read about Gypsum which is Weber's gypsum plaster..
https://www.se.weber/files/se/2023-12/SYS-SE-weber_gypsum_naturgips.pdf
You can first plaster with plaster mortar C 3mm and then fill with gypsum plaster if you want..
But not the other way around..
Yes, gypsum plaster adheres to most things..
I too am very curious about the answer to this question! What is bad from a moisture perspective with gypsum plaster?
Rejäl said:
Here you can read about Gypsum, which is Weber's plaster.
[link]
You can first plaster with plaster mortar C 3mm and then fill with gypsum if you want..
Yes, gypsum adheres to most surfaces..
Is there any advantage to plastering with plaster mortar first and then gypsum instead of just using gypsum?
A
Is there any advantage to plastering with mortar first and then gypsum instead of just using gypsum?
Yes, it becomes more durable..
  • Love
Jörgen Petersson1
Click here to reply
