Hello,
I have taken down an interior wall and insulated behind it. Can the old bricks be cleaned to be put back in place again?
I think it's super nice with standing handmade solid bricks, so I don't want to put up fake bricks, it's not quite the same....
Best regards,
Lars
Best regards,
Lars
Yes, it's perfectly fine! Remove mortar residues by hand, with a trowel hammer or hammer and chisel. There are probably lots of tricks that others recommend. If the brick was used as a wall before without plaster, you should at least have one clean side.
I have repointed the outer façade and exposed the brick wall indoors, with hydrochloric acid you can effectively remove lime residues if the brick looks dirty (mix to an appropriate %). It should work as a "bath" too. Certainly worth a try.
Where can you find hydrochloric acid as a private person? Pharmacy? Paint store? Or do you have to go to a chemist?
I didn't think that far.
Click here to reply
