9,340 views ·
9k views
Calculate angle easily? For wardrobe to fit in slanted ceiling.
I have a sloped ceiling at home and I'm going to buy a pax wardrobe that I will cut to fit in the sloped ceiling. How do I calculate the angle for the wardrobe to fit in the sloped ceiling?
I'm not a math whiz. I don't understand formulas and stuff. Is there a simple way to calculate it all?
The same as the slope of the roof, preferably.
Moderator
· 56 240 posts
It is probably easier not to try to set a specific angle. Measure how high the wardrobe can be where the ceiling is lowest. And how far out from the wall the ceiling is as high as the wardrobe. Mark the measurements on the side of the wardrobe that you are going to saw.
Kan själv!
· Trelleborg
· 18 359 posts
That's what I did.H hempularen said:
And then you should double and triple-check that you're cutting the right corner.
I didn't do that 🙄
Hmm... Yes, this might be the best!H hempularen said:
You measure.
Kan själv!
· Trelleborg
· 18 359 posts
Measure from the back of the "frame" to the wall, this will be measurement A, which you should have at the top edge.
When measuring from A, measure horizontally to get height B directly.
Then cut according to C.
Yes, it is.
